Bosch excel
2 Jun 2006
My Bosch is just over 2 years old and it now dosen\\\'t fill with water when you switch the cycle on. We managed to get the water coming in once but it then smelled of burning rubber. Does anyone have any suggestions
Is the machine buzzing from the rear when the cycle starts - sign of the valves opening but no water supply. HAve you checked what supply is on and no kinks in the hoses.
If there is no noise the likely answer is faulty valves. It is also possible the pressure system is bunged up, or that the timer/module has blown.
Start by changing the valves, cheap and easy job, just make sure water & power is disconnected!
This problem started after a 1 week holiday. The machine sounds like it is running and the timer counts down but no water goes through the machine.... We have just re-filled withs alt as the salt light was on but it is still not happy.
yep its a dishwasher...sorry..forgot to mention that!
it sounds like the pump is permanently on too...
