- Joined
- 29 Nov 2011
- Messages
- 2
- Reaction score
- 0
- Country
Bosch extractor hood model number DHE635BGB fitted in our kitchen about ten years ago. Normally whenever filters clogged up, need replacement then extractor used to be become less efficient. When we change filters used to restore the efficiency back and you can really noticed the steam coming out from outer end of square ducting.
We had good size combination of square and round pipes used in ducting kit, never had problem at ducting side of the system. Lately we noticed that extractor motor is running but steam is not going out. I already replaced filters but no improvement.
I just need advice from any member who comes across with identical problem and what was the solution. I suspect might it need inside cleaning by removing outside grill or might be mechanical moving part stop moving due to any belt broken etc. You guide help will be appreciated.
