Hello,
I have a Bosch Washing Machine that is fitted in the cellar. The U Bend is at ground level which is actually near the roof of the cellar - this means that the waste pipe is connected to the U-Bend vertically. Its about 4ft from where it comes out of the washing machine to where it fits into the U-Bend in the ceiling.
I've had the washing machine about 6 weeks and all seemed fine but it has started not draining properly. There is also a flashing symbol on the display at the end of each wash. Its the one third down from the top on the left which seems to indicate that there is too much foam in the machine. This doesn't appear to be the case however.
Can anyone advise if they think the fact that the waste (the grey pipe) pipe being vertical and therefore the water having to travel vertically is causing the problem? I'm confused as to why it worked fine for 6 weeks but has now stopped.
I'm going to take the grey pipe off to check if there is a blockage (tissue or something in there) that may be preventing the water from draining but would be surprised if this was the case.
Before I call out an engineer can anyone help?
Lee
Lee
