I have a bosch Exxcel SMS50E dishwasher showing an error code 21.
When I start the cycle it fills with water and then it sounds like it is trying to start the circulation pump it sounds like it trys to start the pump twice. Then error 21 appears. I can restart the cycle and reset the cycle to drain the machine.
I have removed the side panels and kick plate, I can see the circulation pump but I can not figure out how to remove the pump due to very little space.
I have a feeling that the pump is blocked in someway, as it sounds like it is trying to start, it may have failed and not able to start.
My question is, is there a way to get to the impeller of the circulation pump, to see if it is spinning, without removing the pump, I can see there is a removable gray plastic cover in side the machine, but I am not able to feel the impeller with my fingers. Or can I remove the pump with out further stripping the machine down if I need to strip the machine further what is the next step.
All the best.
Peter
All the best.
Peter
