Bosch Exxcel WFX145 washing machine
JFB
23 Jan 2011
London
Washing machine won't spin. Water fills and empties ok but drum doesn't turn. :(
Check the motor brushes & belt. There are many posts on the forum regarding this issue.
Hi there
Bosch repair man had just been and replaced the motor and PCB board, I put my first load of washing in and after a few minutes the machine beeped and fault F02.What does this mean?
I think the water outlet hose was kinked! It seems to be going through a wash ok now.
Thanks for tip :)
It's still giving me F02 but it seems to be only on the warm/hot settings ie 40 degrees and above. On 30 degrees it's ok - strange! I've made sure the hoses are not bent and the taps are on - should I check the tap filters?
Check the inline filters & that you have enough water pressure (min 1bar).
