I have Bosch Exxcel washer dryer model number WVD2452BGB /04. It is just coming up to 6 years old and this morning it decided to stop working.
I normally run the machine's cotton eco programme which takes around 1hr and 30 minutes. However when I went to check on it, I noticed that the drum was still full of water and foam despite the timer displaying 1 minute remaining. The cycle continued to overrun by 20 minutes until I manually stopped it by turning the dial to off. From what I observed, the drum was at turning at same slow speed and at no point did the pump kick in to drain the water.
I then tried the rinse programme and was met with complete silence - no pump kicking in and no drum turning - the timer was just running through the programme.
So I tried the drain programme which lasts a minute and again nothing. Tried the spin programme - same result. I decided to give the cotton eco programme another shot and the machine sprung to life but there was no water rushing in (as there usually is during the start of this programme). Instead the drum just continued turning on the same slow speed. I let the programme run its course and at no point did the pump kick in to drain the water. The drum just kept turning at the same speed. No final spin, no rush of fresh water. Just the same motion all the way through. I manually stopped it again.
The pump filter hasn't been cleaned since I've owned the machine. I've tried to remove it in recent years and it simply will not budge. I tried to use a pair of pliers to turn it and almost ended up cracking the cap. So I just left it alone. I did get some problems with draining last year when using the dryer - the machine would stop randomly during the dry cycle with an F:18 error. I overcame it by running the spin cycle several times.
I think my luck has finally run out and the pump has finally given up. Although I did some googling today and found that the fact it gets stuck on 1 minute remaining could suggest a problem with the heating element. Although when I touched the glass on the door it was warm (this was during the 60 degrees cotton eco programme).
Any ideas on what the most likely fault could be based on the symptoms described? Will I need a new machine or is it a easy straight forward fix? And if so what's the best (and cheapest) way to go about it - contact the official Bosch repair service or get a local plumber to take a look? What am I looking at in terms of minimum cost?
Edit: I removed some of the water in the drum to get model number. After leaving it alone for 2 hours, I decided to give the machine another go in the evening. I selected the 15 minute rinse programme and the machine started working - the drain pump came on and the cycle completed. I then ran the 8 minute spin programme 3 times - they all completed successfully and I heard the pump working.
I then selected the 1hr 40 minute intensive drying programme and it has just finished without any problems. Most of the clothes were almost touch dry and there was no water in the drum.
All of this suggests that the drain pump is "alive". So maybe the pump/drain hoses just need a good clean out? I'm a bit worried about the wash cycle getting stuck on one minute remaining - could that also be down to a pump blockage? If the heating element was faulty then surely the dryer wouldn't work.
Any further suggestions and thoughts welcome.
Thank you.
Thank you.
