Bosch Fridge Freezer Clasixx Problem
11 Oct 2010
London
Hello,
The fridge part of my fridge freezer is not working. The problem first started with water leaking under the salad crisper now that has stopped and the fridge is not cooling properly . Can anyone help please.
The water leaking under the salad crisper is usually down to you not cleaning out the drain channel at the back of the fridge.
If the fridge freezer is a frost free then the first thing you should try is to defrost the whole thing for a min of 24 hours.
When defrosting keep an eye on the evaporater tray on top of the compressor at the rear (large round black thing) as it will fill and could overflow with water. The ice in the freezer on frost frees is behind the rear plastic plate or top plate depending on model and as they are not readily visible you need to leave it for a long time to defrost fully.
You then need to make sure the drain pipes and channels in the fridge and freezer are clear of crud/mold/rubbish/etc.
