Bosch Front Load Washer Door Issue?
26 Jul 2007
Bosch 500 series Front Load Washer Door Issue? Washing machine
I have a 500 series front loader washing machine. It is about 6 months old.
A very heavy machine.
I notice the door is heavy as well.
It appears that over time this door has sagged a little. Therefore when closing the door, it does not close as easily as before. I suspect this will get worse and may be due to the hinge being weak, where the hinge attaches or the door simply being heavy for the components involved.
I am the only user of this machine and have NVR leaned on the door or put any weight on it.
Anyone else notice that if they push the door closed it hangs a little lower than it should and doe snot close as easily as when you bought it?
This is under warranty and I have an extended warranty as well, so I am not real concerned but would be if this is a re-occurring issue.
Thank you
Peter
