I took it apart to change the brushes and the motor came apart with the case and now I can't get it to sit back in properly so the case wont go back on.
thanks, I have the motor back together and the drill is working again but I dont think I have enough tension on the brushes against the armature plate, any advice on how to do this, it seems very fiddly
