Order online at Screwfix.com. Deep impact socket set made from fully heat-treated chrome vanadium steel. FREE next day delivery available, free collection in 5 minutes.
The Bosch has the standard 1/2" square drive so the vast majority of sockets will fit, including the ones I've pictured.....some of mine are actually 3/8" but my set has a 1/2" to 3/8" converter in it.
3/4" and 1" drives are available for agricultural and HGV use, but I don't have any of those.
John
With a normal 1/2 square drive ratchet, there is a spring loaded ball on one side of the square to hold the socket on. Look inside the square end of a socket and you will see 4 little ground grooves.
With any impact that can take a 1/4 hex bit inside the square drive, there simply isn't space to have the ball and spring.
