Hi all my Bosch gas hob ignitors stopped working tonight. PCL755MEU/03
All fuses appear to be okay so if it is the ignitor transformer how do i get to it to check and change. It all looks well sealed to me.
You will need to remove the hob from where ever it is fitted, which will probably mean disconnecting the gas, which is supposed to be done by a gas safe registered person. they would probably also check the ignitor switch before replacing the ignitor unit.
