I have a 10 yo Bosch larder fridge (single door) which suddenly stoppped cooling. I suspected a thermostat problem & switched the dial to "off", waited, and switched it back on. It now works when set to full (5). If I reduce the temp setting, it stops agian and I have to switch it off for a while (to warm up?) and then it will work again, albeit only at full power.
Thermostat problem?
The light/thermo cover has a retaining screw, but on removing, the cover won't come off easily.. Am I missing something?
Is this likely to be a standard VC1 type thermo? There is no sign of any surface mounted sensor cable inside the fridge..?
Many thanks for any help, it would be greatly appreciated!
Thermostat problem?
