Bosch Logixx 8 Washing machine degerent pump cover stuck f18
24 Sep 2012
Birmingham
Hi
I got a Bosch Logixx 8 Washing machine which stops during cycle now with fualt f18. I have read up on this & it is a blocked degerent pump. This is on the front bottom right as you are facing the machine. I have removed the cover & drained the water from the little pipe them when I got to turn pump cover it turns a about a quarter them gets stuck. Could be something stuck. Is this a easy fix or do I next to call an engineer
thanks
ice
Thanks for viewing, I managed to fix it. 2x 50p & a lock on plyers. two coins either side of the pump cover, lock the plyers on & gental pressure & persvation I manage to open it, out come a load of coins, a chain & some buttons. Machine working again, misses happy :D
