Bosch Logixx dishwasher SGS65L22GB/07 Pump Problem
13 Oct 2014
London
I have a Bosch logixx dishwasher. Model SGS65L22GB/07. it is not draining properly and is causing the program to stop. The detergent tablet was sitting on top of the dirty dishes when I opened the door. I have checked the impeller for debris but it is clear. I blew down the drain hose and this pushed about a mug full of water back into the machine. It does not seem to be blocked. I need to test the pump but cannot see how to access it. Can you advise how I get access to the pump on this model. Thank you. Patrick
I the sump around the impeller free from sludge? There is a sensor there to tell machine there is water to be pumped out, if it get grease on it the machine mistakes this for water and runs the pump then stops when it fails to clear.
Or do you not hear the pump running?
Is impeller free to move? broken glass can easily be missed when checking for blockage.
