Bosch Oven - Replacement Bulb.
3 Nov 2008
Aberdeen
The bulb needs replacing in the bottom oven of my Bosch Double oven. However, the light is tucked right up at the back r/h corner and completely jammed so cannot unscrew it. Any suggestions how I can remove it?
With soft-jawed grips.
You'd need to wash all the grease off first.
I have the same problem, the cover moves about 10-15 degrees but with the silver socket moving as well. Don’t want to damage the oven casing by applying too much force.
It isn’t very dirty but presumably dirty enough.
can I force it or will it damage the oven or should I remove the cover in pieces?
