Bosch Oven Wiring Help Please
23 Jul 2006
Argyll
Iv just bought a Bosch oven can some one tell me if it can be wired up the same as the one that came out. It was wired using 2.5mm into a fused 13a box on a spur from the fuse box with a double socket and this 13a box on it?
The oven uses 2.9kw max and seems to require a more heavy duty cable as the connections on the oven look big.
Any help would be good
Thanks in advance
2.9kw is just over 12.1. amps Resistive, yes it can be run from a 13amp DP switched fuse-connection unit in the normal way.
