Bosch PMF 180E - Metal cutting blade
13 Jun 2005
Monmouthshire
I have a Bosch PMF 180E.
Normally I would use a 115mm disc grinder with a metal cutting disc, but cannot access the bolt using the grinder.
Is there is a blade that will cut through a 10mm HT bolt.
i would say no unless you have a dozen blades and a few hours as hardened steel is probably similar to the blade hardness
do you have a picture or access details ??
