My washing machine wouldn't empty so I cleaned out the filter and drained it. When we put it back together again, the cold water wouldn't come in, only hot water. We looked for hose kinks. Any ideas?
Hot water is used on all washes except under 30 oC so try a wool wash to see if cold water enters if not check water inlet at tap if this is ok probably valve magnet at rear of appliance.
