Probably a broken core inside the cable where it enters the machine. You need to do a resistance check between the plug & the input terminals inside the machine.
did it stop dead
was it playing up
was it sparking
was it warming up or smelling
have you tried it in another socket and another tool in that socket
also swap the fuse from a know working tool as a fuse check
