Hi all,
Couldn't find the answer for my problem searching this forum, but see that there is some serious expertise here, so I'd like to bounce a question off you guys.
I opened the dishwasher a few days ago to find the bottom full of water. After bailing it out, I took out the filter and the basket, and checked for any blockages. None, the impeller was spinning freely.
Next, suspected the drain pump, so I opened the machine, took out and tested the pump - it was working.
Reassembled everything and ran a cycle, it turns out that if I hold the outlet hose low (level or just slightly higher than the outlet port), the machine is able to pump out the water, however if I raise the hose the pressure is not sufficient (thus it can not pump the water into the sink connection).
What is the problem here? Can the drain pump still be faulty, i.e. spinning but not fast enough to supply enough pressure? Would changing the drain pump solve this problem?
Any other suggestions?
Thanks,
V
Thanks,
V
