The diswasher has had an intermittant problem which has just got much worse. Quite often open machine to find powder still in the dispenser which is open. The dishes are all streaky and it looks as if not enough water has got into machine to clean/move the powder. Also seems to stick at the end of a cyle with 1 showing on front and the sound of the pump going continously. Seemed that if used 70 degree wash problem happened less often, now does not seem to be working every time. Water is getting in as pre rinse etc and is draining away OK. None of the pipes are restricted/twisted etc. If stop the cycle by opening the front and then restart often shows a longer cycle time left than before it was stopped. Any ideas / is it worth trying to get fixed?
I would really appreciate any answers as do not have enough money to buy a new machine or waste on unnecessary repairs/visits.
