The pump on my BOSCH SHV4313 Dishwasher will not cut-out. The control panel indicator is showing “End” but the pump just keeps on going.
I assume that this is either a fault with the control panel or possibly a sensor? I have disconnected the control panel and reassembled and the problem cleared much to my amazement (see also P.S. below). However, this could have be coincidental as the problem reoccurred after only two days. I have take the control panel apart again (down to the PCB) and there are no obvious signs of damage (the relays rattle somewhat but I guess this is normal?). On reassembly the pump still keeps going.
So before looking at getting the control panel checked out, could it be a sensor? If so, can anyone advise what sensors are connected with the pump circuitry and where they are located? What is the best way of determining whether it is the control panel or a sensor?
I don’t want to spend too much on a repair as the machine is just over 5 years old.
P.S. Just before the problem occurred for the first time we used a different Salt and for some reason nearly all the salt was used in one wash. This I guess could have caused a problem with a sensor. When I removed the control panel for the first time, I also added hot water in the theory that this might clear any sensors – so this may have helped. However, repeating this exercise has not helped a second time. Any indicators as to the likely cause would be very much appreciated.
