Hey all,
Perhaps someone can help. I have a Siemens SL84A. I do not know its Bosch equivalent. The unit is not draining and creating a film on the dishes as they sit in the dirty water.
I have checked the drain tube, it is clear, connected to the disposer (the knockout on the disposer has been knocked out). Inside the unit, everything pre-drain and impeller is clear. There is no problem from the impeller unit to the plastic drain thing that connects the outlets.
It seems like the impeller is not reversing directions? Is that possible? That or there is an issue with the plastic matrix thing?
When I run the machine in its undrained state and monitor the output, it barely gets to the plastic matrix thing and there is a bubbling fountain effect inside the machine.
Any ideas?
Any ideas?
