Hi All,
I've been pulling my hair out with my dishwasher and hoping someone maybe able to point me in the right direction here.
I own a Bosch SPS40C12GB/07 dishwasher and recently the check water light has been coming on within 3 minutes of the cycle being turned on. I noticed water coming through on the inside from a vent in the left corner and then filling the inside causing the float to activate and the check water light to come on.
I decided to take the side of to take a look and what I did notice is that the plastic casing that contains the water was already full! So when the cycle started the inlet kept sending in water and the plastic casing sends the water into an overflow chamber which routes to a circular grill inside the left of the dishwasher (as mentioned above) which is causing it to flood and the check water light to come on.
For some reason even resetting the machine drains the water from the inside but not from the side chambers where it is stored.
I'm not sure where the fault lies here, from other research it suggested an impeller jug but my dishwasher does not have that, it does however have a little wheel that spins around as the water comes in through the inlet which is attached to some sort of reed switch.
Any help would be most appreciated as I think this can be a simple fix hopefully?
