Our Bosch Exxcel 1400s express would not spin so we have replaced the brushes. We turned on a 30 degree cycle which usually indicates a wash of about 1h:35m but now says 1h:01m.
The water is coming through OK - in fact seems a little too much. It fills then does not perform the cycle as usual. It usually fills in sessions with a drum turn between each fill until it is filled to the correct level. Now it just fills and fills with no drum turn. It then stops and drains. Then nothing for a few minutes then comes up with a F02 fault code.
This code seems to relate to water inlet problems but the water is coming in...
We have tried the spin cycle on its own and it worked ok and span as it should as did the drain cycle.
