Bosch W/Machine - Overheats and Soap Dispenser Distorts
22 Nov 2004
Fife
Friend has a Bosch washing machine (not washer dryer) washes OK but overheating occurs which has caused the soap dispenser to distort and stick. As well as internal distortion the front face has also distorted. The machine is about 5 years old and regularly serviced.
Not sure of the model but this one has the dial to set the temperature. Never set above 60 degrees.
This has happened 3 times since new and I feel that there could be a design or manufacturing fault.
Any suggestions please?
What has been replaced previously to sort this out?
The dial you refer to has a switch behind it with a capillary going to the bottom of the tub, this should have been replaced.
If I remember correctly (300 miles plus a few beers since I was there) the thermostat has been replaced plus any distorted parts.
Sleepyhead said:
Looks like it's failed again.
Sorry to be a pain but how can it cause so much heat that the plastic distorts given the temperature at which plastic parts are moulded? This happens even when water is still in the machine.
It's boiling the water, the steam can only escape through the soap dispenser hence the reason the soap dispenser distorts first.
