Bosch washer dryer, fills with water on dry cycle
4 Mar 2003
hi
my bosch WVD24520 is playing up
problems
when put on a dry cycle the drum fills with water and I get the F18 error
when put on a washing cycle it stops at the spin cycle and just turns slowly with 1 minute showing on the time left until you turn it of
if you put it directly on to a spin cycle it spins no problem
what i have tried
checked for blockage in filter and hoses
have seen the impeller spinning while attatched to the machine on spin cycle
have made impeller spin connected to a lead direct to power
checked impeller is tight on shaft
checked pressure switch clicks and that tubes are attatched
any pointers would be greatly received as this machine was nearly £500 and is only 2 months out of warranty :cry:
many thanks mark
F18 is usually a drain issue. It could be the pump (even if you observe the impellor turning), a plumbing issue, partial blockage in the sump hose, or drain hose kinked/blocked.
hi
many thanks for the quick reply
have checked all drain and sump pipes no blockage
have ordered a pump (£10) to see if my pump is weak or intermittent (fingers crossed)
May be worth checking the inlet valves -you may have some cross over on the dry cycle as this uses a cold feed condensation feed I believe.
Resistance checks on the valves with the lid off and power off should tell you if the valves are ok
hi
many thanks mark
Good luck with the valves....it certainly shouldnt fill on a dry cycle I think
it should be just a trickle to condense.
If it isnt a valve then it may be wiring to it (again check continuity)
Failing that then it could be the control board.
hi
all valves (solenoids) check on resistance as does the wiring continuity
@cjapeterborough
please dont let it be the control board cheaper to buy a new washer :LOL:
many thanks for the pointers
hi
got new pump today fitted and everything seems to be back to normal :LOL:
washer completes cycle
haven't tried a drying cycle yet
the old pump was well worn when you turned the impeller there was no resistance then slap unlike the new one
also the new pump gushes water out where as the old one was just a trickle
hope this thread helps others
thanks mark
