My bosch washer dryer has stopped drying everything else is working just does not heat to dry. does anyone know if its an easy fix? Model No WFT2800.Thanks in advance for any help
Take the lid off and see if either thermostat has triggered.
you will see the condenser unit on top of the drum-fan housing back right,
thermostats middle front.
I think there are two elements on this model.
-you can also check the resistance on these with a meter to see of they are o/c ie broken.
Power off and plug out if you decide to go in.........
