Bosch washer, shuts down for 72hr between washes
21 Nov 2006
I have a recurring issue with my bosch logixx 7 integrated washing machine. After completing a wash, if I switch the washer off it will not swtich on again for around 72hrs. When I select a programming using the dial nothing happens, no lights etc. It is as if the washer is dead.
After approx 72hrs it will work again as normal. The workaround we have been using is to simply not switch the washer off between washes. However this is not ideal as from time to time it will get accidentally switch off, which the results in 3/4 days without laundry.
Initially I thought the problem might have something to do with the distance between the washer and under sink drainage point. We have had to use an extended hose to connect the washer to the drainage. I suspected that water might not be draining properly preventing the washer from switching on although have found very little on Google etc to support this theory.
Any suggestions, solutions would be greatly appreciated. Would hate to replace washer only to have the same issues a couple of years down the line.
