Model: Bosch Exxcel 1400 (WFO2864GB)
The original problem was that the drum wasn't rotating.
I replaced the brushes as described in another thread and things are looking much better. However, I'm finding that clothes as still wet after spinning.
Machine seems to be filling and draining ok.
New brushes are a bit noisy - but I guess this is to be expected until they wear in. I used non-Bosch replacement brushes ( http://tinyurl.com/ykzwkb6 ). Should these be up to the job?
Machine seems to be draining properly and I've checked for pipe blockages around the drain pump and the water level pressure chamber/switch - all appears ok
Any help appreciated.
John
John
