Hi guys, can you advise me on the fill level for this machine?
I have a Bosch Classixx 1200 Express washing machine product WFO2467GB/15.
My wife tells me that our machine is not filling to the level it used to. This may have developed over the last 3 years as the quality of the wash has gradually deteriorated. So I am now on the case!.
I have checked the cold water input pipe and the filter at both ends is clear. The manual does not state what the water level should be. I have run 2 different cycle tests with the machine empty. In the first test the water filled to just over the first line of drum holes. The second test filled to just under. The water does not cover the drum paddle at its lowest point. The visible depth is about 4cm (1.5""). My wife thinks the level used to be much higher, maybe about 15cm (6").
Before I start taking the machine apart, can anyone confirm what the correct depth ought to be?
Also, I would like to know if our low cold water water input pressure could be causing a problem filling. I would have expected the water level regulator switch to kick in only when the right level was sensed, even if the fill rate was slow.
