Bosch Washing Machine E-NR WFL 100gb / 12 FD8108600267
This is not the usual "dirty water running down the drain hose" problem, because the hose goes to a dedicated stand-pipe with its own trap which runs through the wall to a yard gully. The water seemed perfectly clean and did not smell stale or soapy.
Instead I am pretty sure it must be a solenoid valve letting by. When the machine is not used for a few days, enough water gets in to leak out of the open door. It might be relevant that the machine was disconnected and left in the room while builders hacked away at walls and ceiling, so dust, grit, or a bit of brick might have got in somewhere.
This model has a hot and a cold fill hose, and I did notice that when we ran it with just the cold fill connected, water dripped out of the hot fill hose, which I thought strange.
It leaks fast enough to make an impressive pool on the floor in a few hours, once it has reached the door aperture which took a couple of days. I have never tested or changed one of these valves before. Do I need to trace which valve it is first? Or might it be a pipe or connection? I remember it was very expensive getting D&G out for a pro repair when the PCB needed changing, am I likely to be able to do it myself? How? I am a bit of a clumsy numbskull.
edited:
Cor, £33 for one of them?
http://www.espares.co.uk/part/washi.../439312/755040/washing-machine-valve-mag.html
edited:
