Hi All, Had a quick look around on here for an answer but the issue I'm having is a little different.
My washing machine was not moving on to the spin cycle so, the machine would empty the water, but the washing would be extremely wet. I could manually spin the machine and all would be ok. Now though, there seems to be no way of encouraging the machine to get rid of the water. It just sits there, churning the water occassionally, even if I put the dial to spin manually. So I've had to dump the water out through the filter drain on the front of the machine. I noticed after doing this, that it was possible to get the machine to spin though, its as if the weight of the water prevents it from spinning! But, although it spins, the water doesnt get dispelled. So, what water was left in after draining it manually was visible when the machine spun, but didnt leave the waste pipe.
I remove the impeller pump and that happily spins when passing 240V thru it and I've checked for blockages in all the pipes... I think!
Any thoughts on what to look at next?
thanks
thanks
