i have a bosh washing machine -model WAA24171GB
i had a filter hose problem which i sorted but when i connected back upthe machine i turned on a washing cycle and pressed start-no water was coming into the drum-i had forgotten to turn back on the water supply hose- i turned off the power to the machine, turned on the water supply and tried again-but this time no lights appeared on the control panel- i checked the fuse in the plug-it is fine-i took off the top of the machine and checked for power where it enters the machine -its getting power 220volts-i followed the two red cables to the control panel and tested for power -one connection has 220 volts , the other connection nothing- im thinking is the control panel blown or would there be a fuse somewhere hidden on the panel board
any help much appreciated
