originally it was the brushes that were too short so replaced and bedded in with crocus paper. All worked a treat for a while then a couple of months later the motor started exhibiting the same symptoms of having under length brushes on the spin cycle going from 8 mins to 1 and never really getting up to speed. Checked the brushes again and they are fine. The multi wire connector for the motor came apart when i took the motor out and I reassembled it and crushed the wires back into the knife type connectors. The Motor spins and washes fine but during the spin cycle of whatever prog we select it backs out at a lower speed and carries on eventually to the next part of the cycle. The washing is v wet at the end of the prog.
Has anyone any suggestions as to what could be the prob? I am thinking of taking the plug apart and hard wiring the connections but as it is working otherwise I think this may be clutching at straws. Hope you can help otherwise a new machine is beckoning and this one is only 8 years old with 3 major repairs.
