Bosch WFB 2005 Washing machine door stuck
20 Feb 2010
Can anybody help please?
Machine has gone through its cycle and pumped out water from drum but door refuses to open.
I have emptied the water and cleaned the pump filter on the front panel but it refuses to open.
I have even give it a swift 'knock' around the door panel area hoping it was just jammed?
Any idea please?
Does this model have a pheumatic air lock?
Rick
Remove lid and place hand down inside to release lock
Please do you have the instruction book for the machine?
Mine is missing.
Did you have resolved the problem with the door?
Many thanks
If you do this please make sure the washer is switched off at the supply, there will be live parts you could come into contact with.
Wotan
