Bosch WFF 2000 not working
30 Sep 2007
My WFF2000 is not working, I replaced the pump 12 months ago which fixed the usual problems found on this site. Now in all modes the motor kicks in fast then stops immediately, then nothing happens. The pre-wash light flashes 5 times. Same thing happens in all modes.
In X mode it goes through the cycle to the end then the same thing, motor spins a few times fast, stopping immediately then nothing. Again pre-wash flashes 5 times.
Pump is working, water is filling, checked all filters etc.
I can't be sure because I can't remember what it used to sound like but the drum seems to grind a little, could it be something to do with the bearings?
What does 5 pre-wash flashes mean?
Any ideas for what the problem could be would be appreciated. Its getting old now, so is it worth investigating further, or should I just give up on the old machine?
sounds like the brushes may need to be replaced. Bosch do both brushless motors and with brushes. I had one that cut out after motor starting, the brushes are not making correct contact thus it fails. Check the type you have, brush assemblies are available to purchase but are also expensive from bosch as the incorporate it as a whole case unit
No idea about the 5 flashes but the description of the motor problem indicates a fault with the motor tacho. Either faulty motor, broken wiring or faulty pcb.
