Bosch WFG 1670 noy heat water
23 Oct 2012
element-27 OHM
sensor cold-4 KOHM
voltage on heater wires-30V
How I can get 220 V
From the figures you are quoting, it looks very much as if the thermostat (sensor) is faulty. 4K ohms is what could be expected when the 'stat has opened and broken the circuit. The 27 ohms across the element terminals implies your heater is between 1.5 and 2kW. If you bypass the thermostat, does the heater work? DON'T leave it switched on with no thermostat though!
