had read all the threads regarding spin cycle problems before I tackled my own machine, seemed to always point to rectifying brushes problems with good results however brushes on this machine were changed only 4 weeks ago by a appliance engineer.
Usual problem of machine washing normally, draining ok but not going on to spin cycle- counting down from 11 minutes ,10,9, and then dropping from 9 to 1 minute before finishing on 0.
Removed and split the motor- removed and cleaned carbon from around the brushes and holder, brushes making good contact with commutator, put it all back together and still wash but no spin cycle. So I pull motor back out, split the motor again to check and notice that one of the brush terminals has sprung a little, so I fix, put it back together and now it neither washes or spins. - ARRgh!!!
I remove motor again - split it and suddenly realise that the heavy middle section of the motor, can be fitted into the two top and bottom 3 pin terminals the wrong way round, easy mistake - so now Im left wondering if I have actually put it in the wrong way and If I have, would this cause damage to other components? or would motor just not work because Im now no longer sure which way is the right way. although motor looks okay, ( no obvious signs of any damage). Suppose the only way to find out is to switch it round and try again.
This machine is a little under 4 yrs old - given that no damage has been caused is there any other possibilities for machine not spinning? washing,
Pump is draining okay-
Any replies appreciated,
Thanks.
Thanks.
