bosch worcester 28cdi fault
7 Jan 2010
Cambridgeshire
just been out to fix bosch worcester leaking from seals on plate heat exchanger and now the bloody thing runs for 5 minutes then goes off and the lights on front flash fast indicating air flow fault apart from aps is there any other common probs as bw tech r saying pcb
did you move the pcb up when you removed the PHE? plenty of holes to get water in directly under the PHE.
yeah the pcb was totally out the way i now understand that from the letting agent this fault has been happening already
