Bosch wta 3500GB dryer not heating
ih
4 Nov 2006
London
Hi
Over 20 year old dryer is not heating any help/ advise or time for new one
Thanking in advance
Regards
Ih
Model bosch wta 3500GB/06
If it's rotating with no heat, it could be the heating element, or the overheat trip - assuming the wiring/switch is OK.
The overheat trip may or may not be a resettable type. If it has tripped, usual cause is poor air circulation (fluff) in element.
  • Thanks
Reactions: ih
Hi rotating with warmish air plus checked no fluff in filter wiring switch ok
I think i need open rear to check reset? ( will it rotate if there was 7no trip?)
Trip only cuts the element off. You suggest it is getting warmish. Warmish might suggest the thermostat is set to low/ out of adjustment.
  • Thanks
Reactions: ih
Thermostat set highest ( extra dry) perhaps warmish not correct i say cold air
Update! Heat element plus trip switch checked wiring all good zero fluff inside element ( neighbour checked with multi metr)
Something wrong with sensors? & where are they or is it the programer( cant see on parts)
