Bosch WVD24520GB washer dryer won’t fully finish wash cycles
19 Feb 2009
Hertfordshire
The machine fills and drains smoothly. Nothing was found in the pump, and no Error messages on the display. On Spin or Drain programs it works properly, and it goes right through to -0- minutes, beeps, and releases the door.
However, on a wash program, (e.g. on SuperQuick), it all starts normally but when it ends after spinning and draining, it releases the door, but the Progress display still shows a few minutes remaining (instead of showing -0- minutes).
It does this with no drying program selected, and does this whether the water temperature is set to Cold or 30 degrees, so doesn’t seem to be waiting for a water or air heating element.
This happens with full load, small load or no load, with or without detergent (none used for testing it over and over again!).
Any hints gratefully accepted!
