Bosh Exxcel Dishwasher - whining noise and much clicking
4 Feb 2015
My Bosch Exxcel Dishwasher started making a whining noise when the sprayers are working. Before the main wash cycle there is a lot of clicking from within the unit.
I am not sure if it is the motor/impellor or a relay. The pump pressure is low, and although the whining noise is recent, the clicking noises have been around for a while.
I have had the unit apart, and stupidly, just had a quick look inside impellor, the motor appeared to turn, but I did not really closely inspect the ability to rotate of the motor and impellor.
Unit is E nr. SRS46A02GB/08
And there is a you tube clip.
http://youtu.be/xmH9NZB6t_A
Is it worth getting the impellor kit, I read if the spacer is failed, the impellor will rub against housing. I have also heard motor failures are often incorrectly diagnosed when it is the impellor.
All ideas welcome thank you
L
Out of curiosity do you hear the whining if you put your ear on the rear of the housing?
It is possible these 2 'faults' are unrelated.
Let me know!
Does it definately drain and is it filling sufficiently?
Cancel existing programme, put a couple of jugs of water in the tub, turn on a programme wait for 30 secs and open door, all water gone?
Now close door and wait for filling to finish, open door, how high is the water level?
Hello
I think you are right in that the clicking and whining may not be related. If I prefill the unit before starting it drains the water. If I let it fill for wash there is about an inch of water.
If I put my ear to the unit the noise comes from the circulation pump front right side.
I need to eliminate some possibilities.
L
Personally I think you need to strip the machine back down (yes I know, you've done it once and its a pain in the backside, been there / done it / got the t-shirt) and inspect / bench test the components.
