Bosh Maxx Not washing cycle
5 Jul 2010
Does anyone know how to help me get washing Machine working again? it is 18months old.
In any wash cycle, the machine starts up and starts flowing water in for about 15 seconds. Then stops and nothing else happens, eventually the display goes off. Rinse and spin cycles all work normally. I have checked for blockages, plenty water pressure, cleaned out detergent tray etc.
HELP! :(
You should post the model number and FD codes on the inside door rim/rear label or sometimes inside the bottom left drain pump cover.
If the machine is only 18mths old then Bosch machines are sold with a universal 2 year warranty so I would be calling them for service!
I assume you have tried with a number of program options and you get the same results?
with the limited info it could be a blocked pressure switch hose,failed pressure switch or control board relay for the valve.
