Bosh WF2001 not spinning and not emptying....
26 Jun 2009
London
Hello
Bosh WF2001 washer, water is not emptying and not spining... just stops cycle before emptying and two lights starting flashing :spine and rinse..
appart from blocked filter and problems with pump can it be something else?
how can I check if it's a pump?
At the moment I can't check filter as I got full machine of water and have no idea how to empty
Thanks for any suggestions...
You can empty the machine by droping the whole of the drain hose down to ground level or lower ( remove the clip at the top of the back of the machine) & let gravity empty the machine. Is the washer near an external door so that you can direct the hose outside? Then remove filter & check for blockages.
Thank you for reply.
I did take the water out. Checked filter which was clean.
Does it mean that I have problem with pump?
If you bow up the waste water pipe can you hear water bubbling in the pump, if not you may still have a blockage somewhere . If you can it may be that the pump is mechanically jammed or could be an electrical problem. You need to isolate one thing at a time.
:D jj4091 THANK YOU for helping me.... :D
machine was not spinning and not emptying water out because the plastic pipe under the sink was blocked.
I took the rubber pipe and left it in the sink than I started new wash and my old Bosh 2001 was working without any problems...
I got this machine for 11 years an didn't have any problems.
I am not sure what will be the best solution how to clean that plastic pipe as there is loads of gray stuff inside blocking the pipe :rolleyes:
Is there any lotion I can use to clean plastic pipe or do I have to detached all and wash it?
once again thank you jj4091
I use a plastic flexible pipe cleaning rod or in lieu of anything else a length of 3 core cable and just push it down through the waste hose a few times. Then do a hot wash to help clear out the accumulated grease and gunge.
or a metre length of 15 mm copper pipe gets right to the end.
Thanks for all replies...
I cleaned the pipe and washing machine is working fine..
