- Joined
- 13 Sep 2015
- Messages
- 114
- Reaction score
- 6
- Country
I have a traditional copper hot water tank, with two immersion heaters - one powered from economy 7 and a 'booster' one powered from the normal mains. The E7 one (bottom of the tank) is used every night. The booster one has had occasional use. Both were replaced about a year ago. The tank itself dates from the 1990s. We live in a hard water area.
The thermostats on both immersion heaters have a small 'reset' button.
Around about every other morning, the E7 heater needs to be reset. There's normally some hot water in the tank, so it's clearly starting its over night heat up, then tripping.
If I try to turn on the 'booster' immersion heater, that trips too.
The MCBs in the consumer units never need to be reset.
I've placed a multimeter across things. The resistance of the heaters is around 18 ohms, which is what it should be for their wattage. No evidence of issues with the incoming mains supplies (and they haven't been worked on recently).
Any idea what could be causing this?
JC
JC
