- Joined
- 15 Apr 2018
- Messages
- 268
- Reaction score
- 1
- Country
Hi all
4 story house 8 rads.
I drained down our radiator system yesterday to clean the heat exchanger. I drained the system using the drain valve on one of the bottom radiators.
I topped the system up, bled all the radiators from top floor down.
All the radiators work fine with the exception of the bottom radiator ( the one I used to drain the system) it is stone cold as are both the pipes.
It doesnt have TRV and both valves are fully open.
I tried bleeding the rad again and there was no air. When I loosened off the drain valve water started to come out.
I am most confused as nothing has changed to the rads.
I dont think it could be a balancing problem as I I only opened up the very top radiator valve ( the room rarely gets used so it has been switched off)
Any advice as to what it could be? and how to fix it?
I was looking at doing the bucket test but thought I would ask first.
Many Thanks
Many Thanks
