Hi guys,
Hope all is well I am refurbishing a property and one of the floors is quite bouncy on an upstairs room. I've already taken all carpets out and therefore managed to lift a few floorboards to see what the state of the joists is.
The joists seem in good enough condition, although it seems as though they have already been strengthened with criss-cross timbers at a very sporadic distance of about 4 feet apart.
This is a back bedroom we are talking about and the joists rest on a load bearing wall below. I have a feeling the house has moved slightly in time causing the joists come ever so slightly loose, hence the bouncing.
What would you do if this was your floor? I'm thinking of removing a bunch of floorboards and simply install some additional bridging like so:
Do you think that should fix the problem?
Thanks in advance!
Thanks in advance!
