Hi all just looking for some opinions on my problem. I have late 1800's end terraced house.
The floor in the bedroom is quite bouncy and as im decorating the room i thought i'd investigate why. I was hoping that it would be the end of the joists needed supporting or the mortar had crumbled underneath them but all this seems fine.
The bounce is worse the further into the middle of the room i go and is a lot worse on the joist which ran across the front of the hearth. The majority of the boards on this joist all squeek and move slightly too where they are fixed as though they have pulled away from the joist.
I have now removed the hearth. This was sat on a frame made of floorboards which was fastened to the worse offending joist and then resting onto the joist closest to the chimney breast.
Could this joist be bouncy because its been taking the weight of this joist for all this time or should i be looking further into it?
Sorry it is a bit long winded and thanks for taking the time to read/reply
