hi,i need some advise.i have built a new boundry wall around my house recently.because house is about 2 feet above ground level than outside foot path,i have noticed every time it rains or most of the time bottom of wall is always wet.water table in our area is high and most of the people have water pumps in their cellers.somebody suggested to lay drain chanel which i do not understand.i have seen some walls which have pipes insurted close to ground level from outside.i am thinking to drill hole into wall and put pipes in it but when you fill it inside soil would block the pipes.how to do it properly.some say put gravel and sharp sand inside before putting soil back on it.thanks.
